RE: Spektrum DX-7 Problem ??
Jack,
Go back to your testing with the original servos in their original positions. When you find the aileron servo jumping around again just swap the connecters for the aileron and an elevator and see where the problem occurs after the swap. If the aileron is still the one acting up it is either servo or extension. If the problem jumps to the elevator (which is now plugged into the aileron port) you know it is receiver.
Rob
