RE: JR 10X trim/ DR problem
HMMM. After some re-programming I discovered that the bug happens when I dial in the different rates for elevator as follows: FM 0=60%, FM 1=80%, FM 2=100%. Adding 30% Expo to all of them, and woala - bug is there. BUT: If I then hit one click of "Down ELE trim", the bug disappears. I recon this si an issue due to "exact neutral position" on the elevator stick...?
