RE: Spektrum with analog and digital servo
Something to try---
I found that the overall response with the DX2 is better than myprior, PCM 10x/9303 PCM systems . So-- I tried the inexpensive 126 JRSport servos Non digital - 3 pole 140 inch ounce at 6v
this is a very fast , accurate setup -with the 2.4.
PS I don't use or suggest you use 4.8 v batts with the 2.4 system - It is possible -if you let the battery level be pulled down with servo loads - to exceed lower voltage required (9.6V--3.5V)
If you don't know how to check voltage under load - find out .It is very easy to do
Tho 4.8 works -- there is not as much room for voltage depression if you stall servos or use high power servos.
