RE: Skybolt hangar and clubhouse
murph,
Matching the checkers was a pain!! I'll probably never do that again.
The plane is around 10lbs and the 91 hauls her around ok. This isn't a 3D machine as you know and she flies good on the 91. But landing speeds a high but does float ok.
One modification I did was to make a "springer" landing gear set up. As you know the landing gear is flimsy so I used some 'pull pull' cable on the landing gear with srings.
PS Fort Bragg is a beautiful place.
