RE: DX7: easiest way to program dual elevators and ailerons?
Hi Guys,
I have checked both the listed setups. I am sure they work fine when using the AR7000 rx with an aux2. They did enable me to disable the flap switch. However I am usinf an AR6000 rx in a small EDF with split elevators. The onty open channel for the left elevator is the gear channel and p mix 5 elev-gear. This works unless I manage to hit the gear switch witch results in the deflection of the left elevator, NOT a good thing. Is there some way to inhibit the gear switch?
thanks
John
