transparent blue
now lay a peice bigger than the area you drew on the wing over the wing, you can look thru the covering and trace where your blue box will be on the wing.....I screwed up here and didnt cut a peice of monokote big enough so I had to use 2 peices of trans blue, but thats OK...I was running low on trans red too
