almost complete
Heres the final
after I use heat around all hard edges I come back over the open wing areas with some monokote trim solvent applied with a Q-Tip. this seals down all edges that dont have heat
good luck....would love to see other peoples flags.....The 1st time you try this it may seem difficult. but if you take your time and be patient...it will not be as bad.....also i was luck to keep the red stripes outta the hinge line. sometimes it dont alway work out that easy......Gator
