RE: Bob Cat Copy Falcon 120 Jet
Yes I had three flights on sunday. on the ali. a little trim , on the elevator, little trim up.
On the ele. make sure that the top of the stab is even with the ele. NOT THE BOTTOM.
The C/G is perfect at 13 inches. I even had one deadstick. and it like to glide. I did not use flaps. The Byron fan system works great at 4-1/4 outlet. I will try 4 inch outlet next , after that some props. I use spring/air Robarts.
