RE: Can't make Yellow Bee fly. Help!
Some people may not agree, but I have enough experience with planes like this to tell you - trust me, the solution to your problem is to trash this plane. Like most cheap 2-CH planes, it does not do well with more than the slightest breeze. The turns are upredictable at best. And the big whammy - you have no elevator control. This plane is simply too flimsy. It's OK for a child to smack into the side of a bulding or tree. But it's a throw away.
Cut your losses. Spend no more time or money on this plane or anything like it. Purchase a 3-CH foamy such as the Multiplex Easy Star. Much more durable and reliable. Start by practicing short flights and getting used to actually having some elevator control. Do some tosses into the wind with no throttle and practice gliding. You'll see the effects of adjusting the CG. (Which by the way is the cause of the yellow bee issue - you probably started tail heavy then stalled and you had no control - no way to keep the nose down.)
Up front, it will cost you more, but in the long run, you'll have something that lasts longer and reusable equipment. Else, you'll end up buying another cheap 2-CH toy and getting the same results.
