RE: problem with 7CAP trim!....help!
I was having problem with dial type pushbutton switch with push function only so I cant choose my another model from current one for loong,hard tries or cant reset the timer etc.Then I use contact cleaner spray from outside of the Tx box towards the root of dial button and miracle,it began to work again easily.So I recommend you to use contact cleaner before thinking to send it back.
