Any Ideas on a good kit cutter
I have a set of Jerry Barrons plans for the Hawk P-6E 1/4 scale. The problem is the way the the ribs are cut,it is very easy to wreck the ribs when cutting before you finish cutting it. The ribs have a D like hole in them and the spar slides throuh then rotates to lock in with a notch cut in the spar top and bottom to hold the rib. Way too much work to cut and 90 some ribs and only two the same in each wing.
