RE: Relocate Antena
Routing the antenna internally will work, especially since the fuselage does not severely narrow in the Ultimate. Make sure you position the antenna tube as far away from the servo leads/servos as possible. The servo leads should also be secured to avoid sliding towards/onto the antenna tube while doing aerobatics. Obviously, perform a thorough range check before you fly with the engine running.
