RE: Firehammer diff leaking
I welded the outdrive to the drive gear. It was stripped and I could not find any more outdrives so i was stuck for a while. This setup is holding up perfectly and now if it goes I have a complete set up, diffmounts and all. The problem is though, when you wled it in like that, there is no way to get the bearings off that side.
