RE: Hitec 5745MG Servo
If you don't set the end point adjustment to 90-95% max you will fry the servo. If you plug in the servo and it goes bad immediately, then the board is shot(happens due to shipping, etc). If it is working for a while than craps out, your epa is too high and you probably burned the board out.
