ORIGINAL: PAPE
ok I am a bit confused here. I have burnt 3 of them on my 4th now. I always set the servo with the front tires in the air and adjust it one side at a time till the knucle arm stopers just rest against the A-arm, not forced just resting next to it, my epa may be something like 120% one side and 126% the other side, but the servo is never forced. What yours all saing is to adjust my endpoint to 95%?? If I do this I wont have full stearing meaning my turning radious will be bigger, is this what your all saing?
PAPE, If you are running a DX3 radio, you can utelize the *C button on your TX to override the ratios you set, and get full response range for stearing. There is a set-up screen option for it in the AUX section of your programming.
