RE: Quadra 42 in Byron P51 -Ignition Help required
The timing is fixed at 26-28 degrees. It doesn't move.
To pull the flywheel, you will need a flywheel puller. They are available at the better auto parts stores.
If you are getting a strong spark, there is nothing wrong with your points or coil.
Does your carburetor pump fuel? You may have the crankcase pressure route to the carburetor blocked?
