RE: Can 4-stroke vibration cause RX interference?
Vibration can cause loose or dirty connections to cause interference. I once a serious "glitch", with the engine running, and tried several times to cure it. When I plugged the battery directly into the receiver, glitch went away. Bad contact in the switch.
