RE: Balancing Mejzlik Props?
Go buy a can of Helmsman Spar Urethane from Home Depot or Lowes and spray on one coat at a time until you achieve the correct tip balance. BTW, the spar urethane comes in gloss or satin finish to match the existing finish on the prop. Hope that helps.
