RE: CYCONS FOR THE MASSES!!!!
Greg, that sounds good to me.....I will have more details later.
AJ, the .061 combat engine has its' exhaust stack tilted towards the rear at about 45, it is open exhaust but you could make a slip fit header to slide over the exhaust stack. The .15 combat has the same kind of exhaust and it comes with a tuned "silencer" that looks like a little pear. You would need to run this engine on a sleek RC plane that a 6.5 inch prop can pull around, or else get a FAI combat plane from George Cleveland and hang on tight!!
Dale, Once you get hooked up with one of these, I'll draw up the P-51 SWR and send you plans if you're interested .
