ORIGINAL: growjd8
i have a question about the motor recommendations for this plane. the y call for the power 15 by eflite and i went with the power 32. I just now achieved 200 watts per lb (218)to be exact. Are u guys going with the recommended motor and if so what kind a watts per pound are you pushing?
Maybe 200+ watts is a little overkill, but if your AJ performs properly and you are satisfied, then you did good!!!!! I would be interested in the following info about your AJ;
flying weight?...ESC amperage and make?...prop size?
