RE: Yellow P-38 build thread
Inner Flaps access panel.
There's not a lot of room in there so I decided to cut an access hatch.
pic 1:
The pencil outline of where I will cut the access hatch to put in the servo for the inner flaps.
pic 2/3:
A dremel cut off disk made quick work of the hole.
Rudders (continued).
pic 4/5:
Rudder parts.
pic 6:
Inside view of upper balsa hinge support epoxied into the rudder.
Not much room in there so I drilled a hole where the bottom of the balsa support is suppose to end so I could look in the hole and just push the balsa support until I saw the balsa support through the hole.
pic 7:
Inside view of bottom balsa hinge support exoxied into the rudder.
Note that this balsa hinge support also gets the rudder control horn so there is a 1/8" ply also CA'ed to the side of the balsa block.
Since the control horns go on the inside of the booms, I made sure the ply is on the inside of each rudder and then scratched in a mark so I can tell later 'which is which'.
