RE: broken gear switch
the problem is you do not have access to gear +100 and -100 in the same pmix as the switch for gear is hard wired. Here is what worked
OK. Here is what I did.
1. PMIX-3
2. OFS to CH7
3. set to -100
4. LINK to OFF
4. SW-A to up
step 2
1. PMIX-4
2. OFS to CH7
3. set to +100
4. LINK to OFF
5. SW-A to DOWN
I used a Y cable for ch7 with my battery meter and gear servo. If ch7 were not used I could have just moved my gear servo to ch 7. You can file this in case anyone ever asks the same question Phil Reuman
