muffler for Wild Wiz
I went and bought an expensive Jettfire muffler for my OS .32 and you are right, it hits the wing. Hence, mine in the picture above uses the stock muffler. Gets along just fine, just does not sound as cool as a pipe. My first Wiz has a TT .36 with pipe, I built a sorta tunnel for the pipe. If you drill out the exit end of the stock muffler a little you can pick up a little RPM and still keep enough back pressure. You need to be sure and not eliminate all back pressure, because the tank needs good pressure to stay running at the high G's the Wiz is capable of.
Good Luck!
Rege
