RE: AVOID THESE ARF's AT ALL COST!!!!!!!!!!!!
The H-9 Extra 260 and 27% Cap 232-G are designed by the same person. I built both of them for friends. I also do the prebuild check and the design are totally diffeerant.Makes me wonder... Parts fit and quality are excellent on the cap.Two extras were built and the stab tube fit very loose in the fuse and stab.I also have the C G sukoi, look like it was made in the H-9 factory. Believe it or not but the manual tells you to check the high stress areas and to add glue if think it is necessary !!!
