RE: OMP Fusion Picture Gallery
As with any ARF is is a good idea to go over allthe covering with medium heat when you first start. The Fusions are no different. Go over all the edges of the covering with your covering iron and medium heat. Any loose edges of covering can be tacked down with trim solvent or even thin ca if you know how to use. I did all this even on my 35% aeroworks yak.
