RE: Bob Cat Copy Falcon 120 Jet
Hi bigtop.
I also set rates to 10 and 20, you will soon see you wont use 10 its know where near enough movement .20 is fine and its still not vicious.
I `thought about mixing in elevator with the flaps but after the first flight it became apparent you dont need too.
only the smallest amount off trim change.
i put a small amount off back pressure on the stick this is fine doesnt cause any probs.
This really is one of the easiest planes ive ever flown of any type.
Regards wingart
