RE: Typhoon 2 by ParkZone
i remember when i was a little kid. at the fun flys they had a j3 cub that would drop candy on the field. it had doors in the fuse that would open up, but you cant really do that with a typhoon. so you would proly have to make a box(cardboard or balsa), and rig the door to where the servo would hold it shut, and when you hit the switch. the servo would move, and the weight of whatevr you put in there will push the doors open.
or if you want to be REALLY simple just put a box on the top of the plane (open on the top) and just flip it inverted and it all will fall out
