RE: CEN MG16 Exhaust Fix
The CEN Magnum .18 engine will not fit because it uses a rotary carb and it's crank is not configured to accept the MG16 flywheel. My Jammin .5CRT has a .18 TM in it and I wanted the CEN MG16 to go as fast. Adding an .18 engine to the MG16 will be a challenge due the requirement to have a small flywheel, engine/transmission brace clearance and the MG 16 odd carb angle that is needed to clear the brake linkage.
