RE: Bob Cat Copy Falcon 120 Jet
Yes they fit very well, all I had to do was trim about 3mm off the balsa at the inner edge of the retract socket. I'll have to check which ones, I've long since thrown the packaging away.
I'm using the ones that I had in my AMD Hawk which I sadly crashed. I'll have a look around for you to see if I can get the info that you need.
BiGToP
