RE: Bob Cat Copy Falcon 120 Jet
Lior and all others,
If you cut off the front wing tube inside of the fuselage, you can
put a Dubro 50 oz tank on the bottom, and a 32 oz tank on top
of the 50 oz. The rotation rod (front tube) is not needed to go
from side to side. If you do not believe me check the new
Bobcat 50 models, no rotation rod, only wing bolt in its old
position.
Johnny
