ORIGINAL: Savage03
Now the thing im wondering from you pros is its a 8ohm 25watt, think it will be ok?
Eight ohms should be sufficient. If you're not satisfied with the voltage level, you can add a second 8 ohm in parallel to the existing resistor -- that will provide a 4 ohm load.
