Originally posted by gusman
...i plan to put ailerons on the bottom wing only
...they say then the bottom wing will stall first and you will be flying on the higher wing. but i dont' know yet. any other tips would be apreciated
I built a 20" span bipe with ailerons on the bottom wing only. Whtn the bottom wing stalls and it is flying on the wing without ailerons, things can get pretty hairy.
I only have 1 other bipe with ailerons on the bottom wing only, but it is a Sopwith Pup and it flies well on rudder. I won't build another bipe without ailerons on both wings unless it can fly on rudder control.
