RE: Futaba 9C w/Spektrum wiring modification
Inconel_601
I probably missed something here. So, please correct me. Spectrum's Futaba 9C 2.4GHz transmitter module + AR9000 2.4GHz receiver set is currently available at Horizon for $300. You can just plug in the 2.4GHz transmitter module in your 9C, replace your 72 MHz receiver with AR9000, then you fly at 2.4GHz. You don't need to modify the wiring on your 9C at all.
If one wants to switch to 72MHz, he can just plug his 72MHz transmitter module back and use his 72MHz PCM receiver.
What is the benefit of this modification?
Please let me know what I missed.
Thanks.
Onewing
