GWS P-51D Mustang Problem
how experienced are you with rc.
if you are a newbie then this is probably not the model for you.
check the lateral balance and if necessary add a little weight to the light wingtip.
make sure the control surfaces are set neutral and let it build up speed before pulling up, it may be tipstalling.
check the centre of gravity also
