RE: possible solider joint problem
[X(] I know this that if you have got the deans plug to hot when you soldered it on you esc the prongs will move and cause a very tight connection. when you solder deans plugs together you need to connect the male and female plugs together and then solder it makes for a perfect fit !
The wheel Chris Huston
