ORIGINAL: MRMcFarlandM
Hi Guys,
the instructions say to mount the tank on closed cell foam. The only closed cell foams I know of are not fuel proof.
what is every body using under the tanks.
Thanks Mike,
I use Closed Cell Foam. I don't worry about it not being fuel proof, cause my fuel tank doesn't leak
Seriously though, use whatever you want. The foam you get from tower or your LHS for wrapping batts. and receivers is just fine. I've also used foam out of an old chair, neoprene from a wetsuit, and once at the field I wadded up some paper towels and used that when I lost a piece of foam and didn't have any replacement. Don't over-think it.........closed cell will be fine. Have fun with it!
J.
