RE: Substitute nitromethane
Mixing fuel is pretty d#m# easy. If you are not using nitro mixing fuel is usually a lot cheaper. Even with nitro it can be cheaper, if you find a good reasonable source of nitro. Changing the compression is also easy, at least with two strokes and if you have the equipment.
