RE: Maybe Fast Scat Cat/Jett
Howdy Bob!
Thanks for jumping in!!
I originally wanted to keep the pipe high so it would not hit the ground first if things got ugly, but in addition to lowering the carb, it would reduce the weight imbalance of the off-center pipe. So, I will see how bad a task it will be.
I am not sure if it's obvious from the pics, but the entire front end is layered in 5.7 oz CF. There is a 1/2-3/4" overlap of the 3 sides onto the firewall, and the firewall panel onto the 3 sides too. Do you think the fiberglass is still necessary??
Thanks again for all your help,
Barticusmax
