RE: Hangar 9 B-25 ARF: Building and Modifications
Craig-
It took a while but I found a spot for the switch and retract filler valve! I think H9 designed the front former on the belly pan so this stuff would fit. I used the plastic CJ tees in my Corsair and B-25 and have not had any leaks...may just be beginners luck. Hope mine performs as well as yours on its first flight. Are you using CJ retracts and what do you think?
Tim
