RE: Fuel not getting to the carb when priming. Whats the symptom?
usually if its a clear line you can see if their is any blockage...i could see him taking th HSN out and cleaning it and then screwing it all the way back in forgetting that it should be turned out about 4 turns from tight. just a brain fart. that would cause all the symptoms hes talking about.
