RE: Heavy or Light
It's a combo of drag and surface loading of the wing. If you have more wing area than needed to maintain lift, it's just extra drag. But if you're wing is too small then it flies at too high AOA and you loose efficiency. To figure it out to the enth degree requires a degree I don't have. I say more power and make sure you can land it to do it again.
