ORIGINAL: tommie!
Do a search on engine break in and tuning a engine after break in. Take your time and be patient and methodical...also learn about nitro fuel and its properties and nitro engine care.
Also get in the habit of checking for screws or nuts and bolts backing out due to vibration. If you are just starting out in rc, I would recommend driving around on ashphalt for the first bit until you get used to the car and if you ever have screws fall out, you have a better chance of retrieving it!
Screws that screw into metal should have loctite applied to CLEAN threads and screws that screw into plastic can use a little super glue. Loctite is not to be used on plastic as it reacts with the plastic and makes it brittle.
Its the basics really that should be covered by the hobbyist so there are no hidden surprises.
No blue loctight on plastic? Sounds like everyone RC manual better have a reprint they all recommend loctight on many metal screws to plastic parts..
