RCU Forums - View Single Post - ASP/MAGNUM FS400AR Rebuild/Overhaul
Old 12-17-2007, 01:51 PM
gkamysz
My Feedback: (19)
gkamysz's Avatar
Default RE: ASP/MAGNUM FS400AR Rebuild/Overhaul
Is it a fit (lack or clearance) or material issue? It's pretty common to find the heat treated parts too hard or not tempered in the Chinese products. Does the snap ring groove have radii in the bottom? Is everything square? Theoretically the side loading on the link pins should be extremely small so the ring groove needs little strength.
