RE: Kangaroo-NitroPlanes-Assembly
engine mounted useing supplied mount. OS .50 SX is held in place with 4-40 machine screws and nylock nuts. Throttle linkage was easy with the guide tube has a slight offset bend to line up with throttle arm, and a slight drop to the servo. Engine bay was pre-coated with? (clear dope?) for fuel/oil proofing.
Fuel tank was discarded. Too many arf tank leaks in the past! Tower Hobbies 8 oz tank was used.
