RE: Redcats Monsoon Thread
Yup here are the close ups and yes the body still fits on it too its like a handle with the body on now!! The bracket i made is out of aluminum L stock and on the other side i used the same back side mounting hole from the LST2, then i cut the front one off and made that mounting section flat with the roll bar, i then drilled and tapped a 4-40 hole though the chassis and mounting bracket and bolted that one towards the front of cut and shaved mounting bracket from the lst2. (the body is on a little crooked from the factory so the body on pic from behind looks a little funny sry)
