RCU Forums - View Single Post - Pitch curve on Blade 400?
Old 12-24-2007, 12:47 AM
choppersrule
Default RE: Pitch curve on Blade 400?
Psindrup,
I post this all the time, brushless motors should run at about 80 percent of there maximum RPM or more. The Blade 400 has a 420H brushless outrunner motor. Outrunners, run alot cooler than inrunners. Half stick should make the heli light, 2/3 stick seems about right if you're in normal mode. As skill levels increase, blade pitch and rpm's may differ. It's alot of trial and error. Be patient and don't crash.[8D]
Best of luck,
Dave / Choppersrule
ORIGINAL: psindrup
I have been told that it is ideal if your heli starts to lift off into hover at about half stick.
With default settings on the Blade 400/DX6i, the pitch curve is 0 degrees at half throttle stick,
which means that you will lift off into hover at about 2/3 stick
Is there anyone that can tell me why this is done this way (and should I change it, once I get my 400?)
Thanks in advance
Peter
