RE: Servo Reversing
Just FYI, I had the same problem with my flap servos and did try changing the connections inside the servo.
As already stated here, the motor is direct conneted to the circuit board and makes the job very complicated.
I was able to work that out and also reversed the pot wires (red/green) and it worked fine.
Now, I'm wondering how reliable to vibration those new connections are, specially the new wires that had to be added for the motor.
I may endup choosing the y-cable or a reversed servo solution, just to avoid any bad surprises during flight.
Anywhere I can get these reversing y-cables online? Couldn't find on TowerHobbies.
Nilo
