ORIGINAL: KRO
on thetoyz.com they have a titanium turnbucle set with blue ball cups made by hot racing with a tool for 20 bux thats pretty cheap imo
These are JUNK ! The 3 Racing ones are OK , never tried the GPM's . I have the Lunsford set on it now and I think they are worth every penny .
calvino , I cant belive your'e breaking these shafts like this ! [X(]
You must be setting the gear mesh too tight , either that or your propeller shaft is bent near the spur gear . Maybe the motor mount is bent ?
The DP drag link is the way too go , its really the only hop up that helps the RC18's sloppy steering .
yeah, I tried the mesh, I have set it with paper (a trick used alot), that didn't work very good, shaft broke prety fast after that, I cant' think of anything that is causing it[&o]
