IMAC basic help
Yep, if you aileron the airplane around at the end of the spins, it's -1 point for each 10 degrees of rotation. I'm using the flying and judging guide as bedtime reading. Just reading and understanding the judging criteria can improve your flying.
BTW, i was practicing the Basic sequence at the field today. Sometimes adding early rudder would cause a combo spin/wing-over. Not good. I found that if you enter with the wings tilted just a little to the direction you want to spin, and add just a slight amount of rudder in that direction, it will break nicely and predictably. It works for me anyway.
