RE: Nitro models pusher Bobcat?
I have just started to work on my new bobcat 25.I am mounting a Lambert micro turbine and I wanted to know if there was a certain thrust angle that you guys were putting the turbine at .I know you guys are using the wren 44 on the bigger bobcat so I figure I would do it the same way as you guys are and should be good.
